I have a Predator 212 Gen 3 with a billet rod, 10k aluminum flywheel, 275 Superjet cam from brown box cams, flat top piston, 26lb springs, with a center exit 3 stage trumpet exhaust, full gov and oil sensor delete, oil return hole drilled out for better return with a Nibbi PE24mm with a 112 main and 38 pilot all on a Mega Moto 80 frame. I just purchased a 53 tooth split sprocket and I’m running a 12 tooth clutch. is this a viable street setup?
