Woods mini bike
Mini Bike & Go-Kart Parts
Are you taking about the brake pedal lever,You should have three pieces the pedal the brake band and the band anchor that goes inside the swing arm,they attach through elongated hole in swing arm.Im away for a week I can supply some pictures when I get back
the first picture is the brake anchor it goes on the inside of swingarm and is located by the axle hole second pic is the pedal it is attatched through the elongated hole in swing arm when you adjust chain tension you have to adjust pedal for the brake have never seen the original pedal bolt.most use a regular bolt inserted through swing arm tightened with a nut when brake adjusted then a few flat washers to space the pedal out and a lock nut to hold the pedal which has to move
