I've been building my Super Bronc. I've got the stock carb and the governor linkage all hooked up. It will start with the choke on, after letting it warm up, as I turn down the choke the engine starts to die, it won't idle or stay alive with throttle. Setting are main 1.5 to 2 turns out doesn't help. Low speed is 1.25 out. Idle adjustment screw is set as well. I did not check the float height when i installed the new stock Tecumseh carb. I am not running the fuel pump. I was hoping to not have to use it. It seems as I might be getting enough fuel in the bowl without the pump. Here are a couple of pics of the fuel line routing.
Any help on figuring out the issue would be appreciated.
