H hb32 New Member May 5, 2020 #1 May 5, 2020 #1 Having difficulty finding which plug I should be using. Presently has a Champion J4C in it and spark is weak.
RobertC May 7, 2020 #3 May 7, 2020 #3 Hey HB...welcome to the OldMiniBikes...! What kind of motor is on your bike ?
R ruppking Active Member May 7, 2020 #4 May 7, 2020 #4 hb32 said: Having difficulty finding which plug I should be using. Presently has a Champion J4C in it and spark is weak. Click to expand... These are replacements: Bosch W225T1 replacement spark plugs Beru 14-5AU Beru Z40 Champion H8C Champion L82C Champion L82CT10 Eyquem 0911007155 NGK 2792 NGK 5110 NGK B7HS
H hb32 New Member May 7, 2020 #5 May 7, 2020 #5 RobertC said: Hey HB...welcome to the OldMiniBikes...! What kind of motor is on your bike ? Click to expand... Saxonette
H hb32 New Member May 7, 2020 #6 May 7, 2020 #6 ruppking said: These are replacements: Bosch W225T1 replacement spark plugs Beru 14-5AU Beru Z40 Champion H8C Champion L82C Champion L82CT10 Eyquem 0911007155 NGK 2792 NGK 5110 NGK B7HS Click to expand... Thanks
smudvapor May 7, 2020 #7 May 7, 2020 #7 If you are really wanted to stay original, the Bosch plugs are still out there, you just have to search a little.
H hb32 New Member May 7, 2020 #8 May 7, 2020 #8 smudvapor said: If you are really wanted to stay original, the Bosch plugs are still out there, you just have to search a little. Click to expand... It’s not totally original and not having it judged so anything that keeps it running is good by me.
