here is another little crazy part I desided to do with the valves. I purchase set of briggs narrow stem SS valves and cut them down to size.
first thing was to cut down the top to the correct size.
and then the end of the stems.
and then make a new groove for the locks.
and then grind a new face on my old hall valve refacer
https://www.oldminibikes.com/forum/shop-tools/155643-valve-grinder.html
then use my new neway cutting set to give me a 3 angle valve job.
if I wanted I could of made the stock briggs valves work. the intake was a 1.125 and the exhaust 1.00
I never double check to see if the intake would clear the side of the chamber head. it would of been very close if not hitting it? now on a hs-50 I believe would be just little bigger and that just might work on that motor. either way on the Tecumseh valves in my opinion they are plenty big enough.
