So I purchased a power washer that came with a Honda GC 190 Engine for only $20 and I was looking to install it on a custom homemade mini (not built yet) but I was wondering a couple of things, first thing is there is no throttle control arm on it anywhere, there is a governor arm which seems to keep the throttle in check by going back and forth I was wondering if I removed the spring from the throttle control valve or the air valve whatever it's called could I then hook a throttle cable to the throttle control and not have the governor moving it on me.
My second question is, if I just adjust the governor there is supposed to be some kind of pin on the bottom to open it up fully or something could I just do that and then attach a throttle cable and go with it that way or what exactly. I will include pictures in the event a visual aid is needed.
