I'm starting this so I don't clog-up others' with my own stuff.
I've had this GX140 for about 25 years and it was always used for experimenting. It was disassembled 10+ years ago and I thought it got thrown out, but low and behold I found the parts! The original head was ported, cut, and modified into scrap, so what now?
Enter the hemi Predator head. Stock 140 valves are 24/22mm; the hemi's are 27/25 and the ports are larger to boot. By my estimation, with valve springs it could move the 140's power peak to over 7000rpm without porting. So I got one. It will be styled after the second-gen Chrysler Hemi in orange with a black valve cover.
Anyone else thinking about this should know that the compression ratio will only be about 6.8:1 and there will be no quench because the piston is so small.
I milled the letters off of the valve cover so it wouldn't mess up the wrinkle finish.
Some more mockup for better throttle response.
