Can you do a pic? What HP ect...
Its a water pump engine so you most likely will have spline crankshaft.
Water and goo corrosion might be on crank and holding it togerther. .WD 40 soak for few hours or more.
I was able to get it off tonight. The piece was screwed onto the crankshaft and to my surprise came off easily. I ended up looking up the engine to see the end of the shaft. It will keep my son busy for a while, have a carb just need to find a gas tank. Thank you for your response.
