Finally am getting it swapped in.
The chain/ clutch guard I' am pretty much making by hand, with 1/16 alum. angle, & 3/32, & 1/8 plate.
The back you can see is pretty much done , other than drilling & tapping for the rear mounting screw.
The front I will slice the angle ,so it can be contoured over the side plate, & then braze welded with Alumiweld rod, like I did on the rear.
Will then make 2 angle brackets for the front to fasten to the side case, & then sand contour & polish the front works, like I did on the rear.
It's ''a lot'' of work doing the fab, but the end results will be well worth it.
Hope to get the rest of the parts to finish it up sometime next week.
I
I
