Work part time mornings in a home improvement store, in the outdoor power equipt. dept., & a guy returned a pretty much brand new Simpson ''pro'' 3700psi pressure washer, with a GX -200 on it.
The dumb @$$ didn't add any extra oil, & the engine would quit running, because of the oil level sensor kicking in, & killing the engine,, so the engine wouldn't get hurt.
Thank God the engine was about 1/2 full of oil from the factory, & seems ok.
I figure from looking @ the plug, that it has maybe 10 min. run time on it.
Comp. seems fine, & it pulls over real nice & smooth.
Anyway,,
the time limit of returning the unit ran out, & the Guy basically just unloaded it back to us, - ''All dollars & no sense ''.
When that happens, & Management thinks it's junk,, they will put it out for sale for 15 - 20 bucks,, basically for parts.
I wasn't going to tell them different,, & ended up getting the whole thing for $18.26 out the door,, with my discount.
''SCORE'' !!!!!!!!!!!!
Guess I can kind'a look at it as a ''killer'' bonus.
Sure beats my yearly raise of 22 cents.
So here is the list of some of the goodies that I will be running on it.
Max torque 12t SS clutch.
65T sprocket.
DID #35 chain
Reworked PMR 212 velocity stack.
Tapered K&N type cone filter.
OldMiniBikes warehouse 3 step under seat header.
RLV 91 muffler, which will couple inside the header,, with an RLV 1' stainless clamp.
Plan on going thru & firing up the engine Fri.
Will keep you posted.
I
Anyway,,
65T sprocket.
DID #35 chain
I
