ran it again a few days later, it will idle on occasion (5+ pulls) but now makes this sort of snapping/snipping noise that i have no idea why its happening https://streamable.com/laet7w
I've never heard that sound before. Who knows, maybe it's just a rattle from something. One thing at a time. Get the idle down and see if it still makes that noise. If it still does, try to start narrowing down what it could be.
Actually, one thing did just come to mind. What did you set the air gap to for the coil? I'm 99.8% sure that's not the issue, but just want to eliminate that.
new issue now i have some time to work on it this could be what is making it run like shit, it starts to rev out on me like higher than it normally does and even turning down the idle screw does nothing so maybe it could be an air leak? i got another video from what it was doing https://streamable.com/gmwsyr
i moved my gas tank out of the way when i was rigging up lights, i knew the bowl was still full so i decided to see if i could troubleshoot a bit more with the gas it had in it, going to hook it back up once i finish mounting my fuel pump and mikuni 24
and when i did try to throttle it up it wouldnt budge but still idle very high
ok i just fixed it i moved my air gap out more to around 35 thou and installed a new 24 that just came in and it works!
is there any way to reduce vibration between my gas tank and the frame? right now it shakes like a motherfucker above like 3-4k rpms and i was thinking of dampening it with some padding between where it mounts
