Here is what I did for my original 66 GTO hurst handle. Cut off the old threads, milled the handle top flat. Then center drilled a hole in the handle, pressed in a roll pin,
center drilled a pc. of all thread and pressed it onto the roll pin. Lastly tig welded the 2 pcs. together. Contoured the weld. Cannot tell it was ever repaired.
