found on local CL , i know its not :chinese: !!! Manco delta 1 maybe. got it with the HS40, the frame has some holes drilled into it and some genus tried to notch out the frame by the carb but luckily i can weld. it will need a lot of love thats for sure!! the B&S on it looks like junk, so i think i may use the HS40 or a side popper 3.5 i have, the HS40 shaft is not drilled out though.
