Fresh off a 1970 Fox, we wont be needing it as the engine will be used in a standard application and would have came with a bowl carb. This is the actual HS40 one, with correct choke lever, throttle arm etc.. used on slanted Tecumseh engines pre 1971. Engine is running but I would rebuild the...
