Short time lurker, 1st time poster.
I'm fooling around with a flat head on a Baja frame.
After some research it seems the problem I am experiencing may be common with the pulsajet. The engine I believe is a 3hp, I have replaced the carb with a known 4hp as the original was worn at the...
It's been a long road and what start off as a circuit racer will be a bad cruiser. With the help of some great people allot of studding patients and saving it's going down.
I acquired a used Lifan flathead (side valve) engine, which I have installed on a bicycle (I know, not a minibike, but not sure where else to ask, figured you guys would know). I downloaded a doodlebug manual so I would know what type of oil to use and a couple other things. The manual shows a...
Found this in an old Tec manual. Although it's rather generic, you can get the idea of how to wire your bike if you have a light coil. Might save some headaches:thumbsup:
