As part of the teardown of my Terra Trailtopper, I discovered there are two steel/rubber bushings inside of the trailing arm pivot with a 10MM rod holding the trailing arm to the bike.
The bushings (there are two) are comprised of a 10MM ID steel sleeve and a 20MM OD rubber bushing.
Has anyone...
I am looking for a complete swing arm assembly to fit a BC-1000 Bonanza Mini bike - currently it is a rigid frame on rear and small shocks in front. If anyone out there has the assembly I am in the market to buy. Will need swing arm jack shafts sprockets and bearings.
