Hello, First post here and a newbie at this although I'm a known tinkerer! I acquired (I actually found this thing in a garbage can...long story!) a neglected mini bike with a partial motor. Last year I purchased two tillers from a local classifieds ad for $10. Got one tiller working with a new condenser and used the 3 hp briggs from the other one and the carb from the mini bike and got stuff running great! I'm way excited to get this thing on the 'road.' My question is that I've been fiddling with a 12 volt headlight to run on this. I've actually wired a momentary kill switch to the wire coming from the coil and it works great. Well, I tied into this wire (from the coil) and found a good ground and connected my light (put a connector in between the light and the engine). Well, to start the engine it has to be disconnected. When it is running if I connect the light it will kill. Am I able to run a light on this setup? I will be sure to post pictures as things progress. Also, if detailed pics of the coil/wiring are helpful I'd be happy. Thanks in advance for any/all advice!
