While I have never had a an H25 apart that is that old, Most of the small frame H engines mid-late 1960's had a compression bypass hole in the valve seat. That was the "ezee-start" as noted on the balloon decaling. So compression tests are misleading on these as well as many other small engines due to most of them having a some sort of compression relief.
I stuck a carb cleaning tip through the hole in this 1968 H35 I am rebuilding right now as an example:
[/QUOTE ] "If you miss one you'll never get them all"
You are a well of know how . thanks so much . Comp. is 90 psi after i tightened the head bolts hot but it runs crappy .T. his little motor will be the death of me
