@Lizardking. I built an electric start clone and have had to rewire it to move the switch into the battery box which will sit atop the engine. The box will house the electric distribution panel, starter switch and battery charger port. The electrical on the bike will be run off battery. I built one box in the past but it was a little small.
For the clone I have a Mikuni carb, Mod 2 cam, 22 lbs springs and a billet rod. Have not put in the cam, springs or rod until I can make sure I can get the right billet flywheel with the starter ring. It will be cruiser so I didn’t want to go crazy.
I had to go with a PRM jack shaft and ARC engine plate to accommodate moving the engine a little to the left so the front and rear sprockets line up. Not sure on exhaust yet. I have an older one from HRM but not sure if I’ll use it.
I know
@FOMOGO and others have done some neat stuff and I’m always on the lookout for new ideas.
