2018 OldMiniBikes build off entry. Just for fun/drag bike class
#23
The head was milled. No port or bowl work has been done yet. Head was slightly milled to stop from rocking. The combustion chamber was welded so we can shape it.
Sent from my iPad using Tapatalk
#25
Just a small update. No progress yet. But I had my main focus on my Harrison build that I wanted to have finished for autorama. Time to get going on this motor
#26
Head is a little closer to being finished, need some epoxy to fill small pits in the port. Rough assembly on the short block to follow.
#27
Plugged the governor holes, low oil sensor wire hole, and mocking up top plate and fuel pump.
#28
Had the piston milled and gas ported. All clearances are clear and set during rough assembly. Next step will be final clean and assembly.
