I have a Baja 50 cc,4 wheeler,the wire harness was a mess,and key was missing.so I took all the wirering harness off.and I am setting up a more simple set up..my problem is that it I cannot get spark to the plug??I get voltage from one red wire from the engine, there r 4 wires from the engine..the coil has 2 lead wires I ran the live wire from the engine to the coil and tried to use the other coil wire as a ground and also to the other engine wires but no spark to the plug??is an electric start(battery)
can anyone say what the 2 leads of the coil should conecct to??this engine has a light set up also,bit not concerned with that stuff..
thanx
thanx
