I have an early 60's 4hp Briggs all stock with the pulsajet carb that starts to pop and sputter at higher rpms. It has always run great with no issues up until about a month ago. It starts and idles fine and runs great up to a certain rpm. I thought it sounded like it was running out of fuel but I've cleaned that carb several times and it's got a new diaphragm and gaskets. I've tried setting the needle lean and rich and it still does it so now I don't think it's the carb.This engine does have the old breaker points ignition. I've set the points gap, the flywheel air gap and the flywheel key is not sheared. What do you guys think the cause could be? Is it the old points ignition going bad?
Thanks-Chad
Thanks-Chad
