5 hp crank in a 5.5 block?
i have a 5.5 ohv briggs that someone gave me, it was on a pest control truck for the sprayer , it has a gear reduction drive on it that i don't think will work to good, so i heard that a flat head crank would work , if so does any body know what year or model that will fit and what else i would have to do? ,or just get the right crank.:shrug:
125ccCrazy
to use the flathead crank in the ohv block you will need the stroker rod, piston, conversion timing gear, conversion oil seals, converion pto bearing
