I have to start planning the parts for a build. I need to try to build a 5hp, That runs strong and will not be too troubled by running higher rpms for probably a little more sustained than normal, and externally look like a stock 1967 4hp
So that limits me on the carb to the old pull choke and even a hot dog muffler (I have a plan for the muff though)
This will be for a 1967 Fox campus, I do have the title for the bike so There is the opportunity to get it street legal. Not to mention we are relocating my mother from north FL to down here by us and if this deal goes though on a house we are looking to buy, she may live within a mile of me. I am sure I'll be running over there constantly! Not to mention we are in a great little area of our town on the historic side with slower roads, great parks on the bay and shopping ares etc., so something that can run in the mid 30's in a 5 mile radius is pretty doable.
Backstory out of the way Here's what I have collected so far:
Here is the original 4hp from the bike, which the new engine has to look like so I am stuck with an earlier style block with no oil sensor hole (so that means bushing case) block.
thankfully the OG shrouding is in good shape to redo and that tank is an NOS one I ran across awhile back (just bolted it on there to keep parts together in storage)
Here is what I bought with intentions to use for this awhile back:
It is a mid 80's 5hp engine that has some mods, The block is a perfect match externally ('cept for the 13's cast into the side by the breather
) This one is a ball bearing sidecover which does not match but that is something that will be hidden behind the clutch and guard so that is OK. It's been sleeved and is .010 over, the piston is a Wiseco and Horstman I beam rod with inserts. when I got it it did have what I think was a Lunati cam (this thing was built in the 90's If I remember right) but I sold it off The valves/springs that are there though dont appear to be anything special...they are not beat but I do intend to do all new up top to match a new cam. A possible downside is there is some porting done, maybe a little more open than needed for what I want to do. I found an NOS crank to use as well.
What I need to figure out is a good aftermarket cam for my app, or would one even be needed? I am going to do what I can to the carb and hopefully get it opened up a little, but I won't be able to achieve too much with the pull choke. for the muff I plan to drill out the center insert so it will as open as it can. As stated I would love for this bike to cruise at 35-ish mph with hopes that it could peak from there in the 40 range on a whim or if needed to get out of the way, yet still have good low end take off and power since I will have to deal with light traffic....sounds easy enough....but probably not
One of the other Campus bikes I had was also B&S 4hp engined bike. I would say it was happy mid 20's and would peak in the mid 30's before it started talking back....in and angry tone
sounded like valves so that has me worried about using a stock cam, and valve train. Actual internal condition of that engine was unknown though. It appeared to have never been opened up and I had just set the points, cleaned the carb and went, so I'm sure it could have used some lovin' inside.
I don't have much experience with the briggs 5hp's other than tuning one up here an there I've never had much time inside or even on them to gauge how they run with different parts etc.. so I am a little lost in respect to how far the stock valve train will take you.
