I need some more power out of my "super stock" 97cc motor, so it's time to make a budget performance cam using one stock 2.8 cam and a very old, very used westinghouse arc welder. I'm using the cam from my spare block for this experiment. The super stock engine will stay together until I get the performance cam completed, then I'll swap out the stock cam. First I checked my spare block to see what the cam looks like from the factory. It's got roughly .125 lift. I counted the valves as closed until they lift about .015 off the seat. Intake opens at about TDC and closes at about 22 degrees after BDC. Exhaust opens at about 33 degrees BBDC and closes at about TDC. The picture is a 2.8 cam next to a spare briggs 3.5hp cam that i'll practice on before I ruin the 2.8 cam. I'm not going to make the lift any higher due to clearance issues with my "hack job" head. I think I'm going to advance the cam a tooth (about 8.2 degrees) and add some material on the "back" side of the lobes. Then I'll keep checking things in my spare block as I grind things smooth...we'll see what happens...
