Hey Guys, I'm looking for some advice on a Tecumseh 5.5 HP L head engine. The Engine in question is new and has an all aluminum cylinder wall. I would like to port out this engine, shave the head, and install a reground Tim Isky cam. My question is, how durable is an Aluminum cylinder wall engine? I don't want to waste my time and efforts to build up this engine if the cylinder wall is going to get trashed quickly. What do you experienced engine builders think is the chance this engine is going to hold up well to adding some HP to it? I've seen a number of old engines with trashed Aluminum cylinder walls, but none of them have been owned by me since they were new so I have no Idea how they were treated and if they had regular oil changes done to them.
The Snow King engine I have has lighting coils on it, which I need, and those parts are close to impossible to find for the older Steel sleeved HS50 engines. I would actually be willing to fit a steel sleeve into my newer LH195 SP block, but looking over this engine it doesn't appear to have enough cylinder wall material to over bore it and fit one in. I'd also be willing to use an older steel sleeved HS50 block I have if I could find some lighting coils to fit it.
So do you think an Aluminum cylinder wall block will to be durable enough or do you think I should look elsewhere? Is it possible that some other model Snow King 5.5 HP engine has a steel sleeve? Thanks!
Eagle
Eagle
