I bought a DB30 a while ago, and I ripped the 97cc off and swapped out the 212 because I know those motors a lot better than the 97cc. Now my goal is to get this little 97cc running. It's been sitting in my garage for a while. I found lots of problems with the carb when I first opened it up, and I ended up buying a brand new carb for it (because the other one was beyond repair). So, I stuck the new carb on, gave it some gas, and it fired up quickly. It ran well for about 4 seconds, and then it died. I started it again and it did the same thing. It does need choked when starting. If I give it gas, it does run a little longer, but then it dies quickly. It's almost like it runs out of gas, but there is plenty of gas getting there, and the carb is brand new, so no clogs. I was wondering if I might have an air leak somewhere between the carb and the block? Would these be symptoms of this problem? I may need to swap gaskets out. Any input would be greatly appreciated.
Thanks!
Thanks!
