I have a clamp on multimeter I think it's an Ideal brand. Is there any volt meters or anything else that I should or could get to make this setup any better? I plan on making this control panel as nice and professional looking as possible.
No I think that's all you really need
A NEMA size 1 contractor would be nice, a heavy duty relay rated at around 20 or 30 amps would be nice for the start cap.
Timer is optional....
A couple of of good push buttons for a start stop station.
Maybe a 30 amp local disconnect for the whole thing.
You know a complete Size one starter would have most of what you need ( scrap yard thing maybe ).
That leaves finding a heavy enough relay to deal with the start cap.
Something like this would probably work in a pinch from an AC unit
Trane American Standard A C Contactor Relay 2 Pole 30 AMP CTR1582 CTR01582 | eBay
I really have an aversion to selling my hoards of stuff because they allow me to sleep at night safe in the knowledge I can rewire society in my own image after the giant solar flair blows up all the Ipods and VFDs ( you are superposed to do this now
ut: and quietly except I am eccentric ).
HOWEVER I could have a look around downstares and see what I can scare up.
Seems to me I have some NEMA 1 CCL contactors and a couple of 60 amp IEC rated AB contactors.
I probably have everything but the caps.
I don't believe in capacitors or trust them so I don't stock them....
I think they are the devils electronic device.......
Nothing should hold electrons Hostage when the power is turned off!!!!
