it is an "HS50" 5hp small frame Tecumseh, look at the little tag that is screwed to the cylinder air deflector on the left side of the engine just above the torque convertor cover. It will give you the engine specification Numbers (I think those were HS50 67028A engines) for ordering parts as well as a date code First digit of the date code will be the last digit of the year and the other three digits will be the day of that year. Your first digit will most likely be between 1 and 3 (1971-1974) as usually those are the only years they produced that engine configured like that which will also put you in the timeframe of that bike,
