Howdy all,
Long time no post. I have a question for those with experience regarding Azuza 4.5" drum brakes. Which way do you install the brake actuator lever? Do you install it so that it rotates counter-clockwise or clockwise? For Counterclockwise rotation the curved actuator lever would point upward. For clockwise rotation the curved actuator lever would point downward. Currently my brake actuator lever is pointed upward. Does it matter?
The brakes on my Side Car build have never really been stellar. Unfortunately the previous owner of the mini bike has cut off the lower tab that secures the brake cable and allow the brake lever arm to be installed pointed downward giving it clockwise rotation. I have always wondered if the brake would work better if the brake lever arm pointed down?
Another thing I have discovered is that the steel backing plate for the brake assembly is drilled for a 3/4" axle. My axle is 5/8". So it has been a challenge to keep the backing plate perfectly centered. I have ordered the correct steel backing plate brake assembly drilled for a 5/8" axle. This may be causing most of my problems.
As always, all comments are greatly appreciated!
Hec
Here is a pic of the orientation of the brake actuator lever. Note the lower bake cable securing tab has been cut off.
We have had a lot of fun with it. Just wish the brakes were better!
Hec
