Black is too rich, drilling jet even richer !!
Thanks a lot for this advice. Does this mean I should drill out the main jet?? How would that alter the situation? BUt yes I'm beginning my modifications now, and i have an UNI air filter on the way. Thanks
Don't drill yet ! You already have too much fuel ! I would open up the air flow first. Run it and see the change in the plug, if it goes light brown you have what you wanted. If it goes white then it is too lean and now you can open up the jet. Start small, be patient and "tune it" by watching the plug. Once it is a nice light brown, stop drilling otherwise you will go back to black.
I know some guys just jump straight to the # 90 or the # 92, that is okay but it is a "shot gun" approach. You have the time, get your engine to " talk" to you, you will understand it and be able to trouble shoot it better in future.
As for the comment about "rings", I 100 % agree if they are passing; the oil from the case can make the "black". If you can check the cylinder walls for "oil streaks", go ahead. Otherwise assume that it is lack of air and carry on with opening up the air flow.
Not trying to take away from guys who design "Stage 2 kits" etc. They have done a lot of work to figure out what will work for the "majority of engines". They are upgrades though ! not repair parts, if you have a problem "upgrading might not fix it, you might just have the same problem with an upgraded engine.
If you take a "troubleshooting" approach you will know much more about small engines and how they work, rather just throwing money at them because it's better than doing nothing.
Your approach is good, ask, read, do and learn! Keep us posted too so that we all learn too !
