Hello, I have been working on a Briggs 5hp engine. It's model number is 130202. I bought a crankshaft with the demensions I needed but I guess it was wrong since the flywheel won't go far back enough on the crankshaft. Does anyone know the right part number for this model with a 3/4 in shaft with a threaded hole? The crankshaft I purchased model numbers are 261142 and 494071 for a 130292. I also have a 130232 block. Will this crankshaft work with the 130232 block?
Thank you!
Thank you!
