what valve spring is everyone running ?
that all depends on the cam you plan on using. can put you in the pall bark.
for example: if you just want to stay with a stock cam ,but still want to rev it little higher and it will when engine is setup correct and do not forget to use a billet rod. the old style stock hs-rods will break.
i would go with the animal retainers and keepers and animal 16 pound spring. all this will give you the correct valve spring setup.
some people in the pass have just shim there springs to make them stifffer,but then you can run into problems too with coil bind or even worse. have your 40+ year old springs just break. not worth going down that path. for little amount of money you can purchase the new parts. i call that cheap insurance..:thumbsup:
i'm not a real big fan on milling alot on a flathead. i would stay away from milling alot and try to concentrate on gaining power different ways and there is alot of ways of getting more power out of a flathead then trying to mill the head.
in my opinion i think milling the head is the least amount of power gain in a flathead engine. something else to think about too. go to youtube and study how the frame travels across the head on a flathead. you can clearly see it needs the space for everything to travel back and forth correct. if you tighten up that air space? kind of like choking it.
not a engine expert......just a gearhead.....
