The learning continues..... It has been suggested that I look into TAV's to replace the centrifugal clutch and a TAV2 does look good. Just wondering about.....removing a centrifugal which I am unable to remove from a 212 Hemi crank shaft, no set screw, no key in the keyway, appears to have been pressed on the shaft by a bolt and washers, removing the bolt does not allow the clutch to slide off the shaft, perhaps a puller is needed? I'm having little luck thus far.
Replacement looks simple enough once old parts are cleared but I'm also concerned with reviews saying that the wrong bolts are commonly being shipped as factory applications but are the wrong lengths or sizes.
The one I am looking at is a Comet TAV2.
Any help or advise is welcome.
