Some baja warrior/heat frames, I've had to switch the rear axle spacers to the opposite side.
Watch for rear tire center to frame, some can be way outta wack. Then that gets into fab work with new engine plate to start.
Earlier frames were very weak up around the neck. I've found it best to go ahead and add gussets asap, or they break fairly quick.[/QUOTE
Excellent Thank You. I will try te spacers swap first then go on from there.
