Is there anybody out there that's made a alternator/generator that functions on small engines that didnt have one from the factory? Im building a bike with what i presume is an 80's(??? havent run the number yet) Tecumseh 3.0hp edger engine. The bike will be using a headlight and turn signals as well as a brake light, so power is a must and battery placement is an issue. Had a thought about switching the flywheel to a points one, taking off the solid state magneto, and then putting a plate assembly from a outboard on there. Taking one of the two ignition coils off and replacing it with a outboard charge coil. The smaller ones from the 9.9-15hp outboards make about 5-6 amps of AC and the rectifier makes it dirty DC(not very stable voltage 14-16vdc, for lights this should be fine though) Any thoughts? Any better ideas?
