I am rebuilding a Tecumseh HS50 i just got.
the engine is basically striped. I took of the flywheel and all that and then tried to take off the crankcase cover.
the seal between the bearing and the crank cover is too tight, they wont seperate.
When i try to pull the cover the crank wants to come out too.
How can i break the seal?
What if i put wedges all around and start hammering them in? Will they seperate eventualy?
