destruction of the beast
Hello everyone here I'm going to be doing a little log of rebuilding and painting of my taco 100 mini bike. I bought this bike a while back planning to fix it up and make it look some what pretty again. Here are some pics of the tear down.
Those welds were a pain to grind down and I think my air impact either froze or broke. Does anyone know why someone welded those extended bars on the swing arm. I think because the shocks are a little taller or maybe because they didn't have a jackshaft at the time. Any input if I should remove them or leave them on.
No idea why they'd be there. On my Taco 99 (essentially the same setup) I have one-inch longer shocks, and it's no problem at the stock mounting holes. :shrug:
Maybe larger wheels were on them at one time, and they needed clearance?
I'd get rid of them. I went with OldMiniBikes jack shaft setup. My favorite mini.
You sure got a nice bike there to mess with.
Good news is I took them off with an angle grinder and started to sand down the frame. Bad news is while I was sanding I noticed a little blood on my hand the cut is nothing more then a Ez superglue bond but whoa it was really close to cutting that Finger in half.
gbabins1
Hey winter is over time to bust out the bikes. Here is this make shift gas tank I made out of mini propane tank looks good so far.
I have made a few tanks from propane bottles also... one word of caution: JB weld will eventually leak when exposed to gas / long term. I would use gas tank putty. So far I have used it with no issues. :thumbsup:
The l.p. tank is for my mini grill. Advise to be very carefull when handling these I removed the valve core when the tank was completely empty and let it sit for week. Before I drilled into it I lit my lighter by the opening where the core was and there was a little flame. :p there might be another way of draining all the gas out with water or something. But I drilled into it anyways with no big booms. The fitting is a fuel line and the cap was from the garden section of the store. Here's some paint primer I did today.
#18
Good idea with the scotch bright pad I had a couple laying around the workshop. Here's some pictures of the paint time to dry and assemble tomorrow. Tonight ill tune up this tecumseh engine I can't believe it take 30w engine oil thats some thick stuff.
