W wiideeye New Member Jan 7, 2013 #1 Jan 7, 2013 #1 I need rear wheel assembly with a disc brake and sprocket!
Pit Bug New Member Jan 7, 2013 #3 Jan 7, 2013 #3 I've seen this one, but I can't find out if it is one for a disk brake or not? Doodle Bug DB30R-175 Rear Wheel OEM .
mmisterbungl New Member Jan 7, 2013 #4 Jan 7, 2013 #4 Pit Bug said: I've seen this one, but I can't find out if it is one for a disk brake or not? Doodle Bug DB30R-175 Rear Wheel OEM . Click to expand... if it's OEM, then it is.ut:
Pit Bug New Member Jan 7, 2013 #5 Jan 7, 2013 #5 mmisterbungl said: if it's OEM, then it is.ut: Click to expand... My Doodlebug came w/ a drum brake, not a disk brake. :shrug:
Pit Bug New Member Jan 7, 2013 #7 Jan 7, 2013 #7 mmisterbungl said: kind of doodlebug would that be? Click to expand... A new one. From what I understand, the Doodlebugs made after 2007ish have drum brakes on the rear.
cumminsbayou New Member Jan 7, 2013 #10 Jan 7, 2013 #10 how are the drum brakes doing for you? do you like them
Pit Bug New Member Jan 7, 2013 #11 Jan 7, 2013 #11 cumminsbayou said: how are the drum brakes doing for you? do you like them Click to expand... I don't think it will last long w/ the Predator, that's why the opener of this thread and I are looking for a disk set up I suppose. :laugh:
cumminsbayou New Member Jan 7, 2013 #12 Jan 7, 2013 #12 the disk brakes aren't worth a crap either you would need hydraulic
Pit Bug New Member Jan 7, 2013 #13 Jan 7, 2013 #13 cumminsbayou said: the disk brakes aren't worth a crap either you would need hydraulic Click to expand... I already have the hydraulic line and caliper, just need everything else. The main thing is I can't find the rear hub assembly?
