So I have a new clutch on my minibike and at the same time I have installed the jackshift kit. I put a few drops of oil on the new clutch bearing in case it comes dry from factory.
Since its first start its been making a high pitch noise when the bike is going very slow or still. If i pick up the back wheel it does not rotate.
Is this from the left right play of the clutch which is now on backwards from the previous setup causing this noise? It is a high pitch rattle like noise and it goes away as soon as the clutch engages.
https://www.youtube.com/watch?v=HysX7z6bTJE
Its going to be tricky keeping this clutch clean and lubed up with it on backwards :/
