If you can find copper sheet that's about 1/2 as thick as a normal exhaust gasket, you can punch them out of that & double them up.
Some exhaust manifold to head pipe gaskets on misc. 4 cyl cars, a lot of times will have enough area on them also,, to punch out gaskets for small engines.
You can take different size ''cheap'' junk sockets, depending on the sizes you need,, & grind around the outside tip of it to a ''sharp'' tapered edge, & use them for gasket punches.
I
