Falcon scrub brake
I just bought a Bird Falcon yesterday...everything is fine except i had problems with the scrub brake sysytem....i almost have to put the foot pedal to the ground to even get it to slow down...i replaced the spring with a new one and it still has the same problem. The scrub pad flipped a couple of times over and locked the back tire up?? is the foot pedal too long?? should i try to fix the scrub brake system (any ideas) or should i try to change to a different system and what would you recommend?
Most likely the shoe is worn out or you have too small of a tire on it. You should have maybe 1/2 inch or less between the shoe and the tire.
I have 4.10/3.5 4 tires on it now......can i bump up to the 5" without having the change the wheels? i'm sorry very new to this....first mini bike, small engine....etc. but desperately wanting to learn.
thanks it's my first! so any suggestions etc...would be greatly appreciated...i love it...i'm hooked.
view my photo's to see another pic....i'll be posting more.
