Whoa. I'm no expert but it looks like the trial is the wrong way. I think you need the axle behind the tubes not in front of it. You now have negative trail. That could be Very dangerous at high speeds.
I'll let someone more knowledgeable chime in on that.
Side to side steering... Probably about 45 degrees for maneuvering around a garage etc. To little and it is takes more forward and back twisting and turning to get it turned around in a tight space. You don't want the handle bars to flop to the side either...
Also, your gearing as is without the torque converter is 7:1. Figure in the torque converter engagement torque and you are at like 19:1 !!!
With your seat placement over the rear axle that thing WILL wheelie easily, maybe to easily. My suggestion to switch the two jack shaft sprockets. That reduces the 7:1 portion to 4.28 then when you factor in the torque convert you are about 11.5:1. That is much more ride-able in my opinion.
Danford1
rake and trail
Danford1
rake and trail
