So all intek/animal/206 Briggs engines have the “studs” in the block for an alternator and starter. Whether they are drilled and tapped for it depends on the model. (From what I can tell, the animal blocks are all drilled and tapped). On my version of the Intek, all 4 holes were drilled. And only the top 2 were tapped.
I tapped the bottom “studs”. They use #8-36. And ordered 2 more bolts from Briggs to attached new alternator that should push out 5 amps DC with my flywheel. Below was the previous alternator...
Here is the new alternator...
This new set up, if it works should be enough to run lights and have enough extra to top off the battery for the 12v starter that also on the way, and not sure if it will fit/work yet.
