Hey OldMiniBikes,
I've got this already modded Rupp Scrambler. The motor won't start, it had less than 20psi compression and during a leakdown test it is blowing a whole lotta air out the exhaust.
I've got 2 question has anyone stuffed a GX160 into one these and since someone pulled the jack-shaft and torque converter and directly connected the clutch to the drivewheel. Do I need to go back to a Jack-shaft torque converter setup or can I run this but need to make sure I have a certain number of teeth front and back.
