They should both fit, It is my understanding that the one on the left is the newer/newest version wheel so if you know the years of your engines you could fit them that way.
If the flywheel fits under the shroud and has the same diameter as the shaft it will work i done it before and my engine ran dam good ... Those two flywheels look to be equally balanced...
