H50 Pinned Crank Gear
usually slide off pretty easy, If you had issues becuase that cam gear bind it may have buggered the pin and it will be like dealing with a clutch key thats messed up and might have to use a puller. but I have had them slide right off after pulling the bearing off.....dont forget that there is a spacer between the bearing and the gear when you reassemble.
Rooster63
I don’t have the Bearing off, as of yet. Thanks for the response. Much appreciated.
