Hi, I have a new later model H50 short block. The intake, valve guide looks like it wasn't pressed down all the way, and will not help keep the valve spring cap centered. The exhaust looks correct. Funny thing is the old block was the same way. I have punch that looks just like the Tecumseh valve stem tool. I used it on the old block with some heat and copper washers and it sat the guide with no problem. Do you think I should press the intake valve guide to match the exhaust valve guide on the new block? Or did they install it that way for a reason? Thanks, mike
