Getting lots done on the Heald VT-8
I wasn't really digging the looks of the mismatched pull start and fan shroud on my newly acquired Bronc. I wanted the classic white engine as these were when new.
I was given 2 additional HM-80 engine and one is from 1971! Classic off white tins and the flywheel mesh screen that so many engines utilized at one time.
I swapped them over to the current engine. I wanted t swap the whole engine but unfortunately the 3/4" PTO does not have a tapped 5/16-24 threaded hole. I thought about drilling one but it has to be spot on.
The white 1971 engine even has the 3 pin charging/lighting coil vs the engine that's in the bike now is the later design with electronic ignition coil and 1 pin with a lower output coil for just a single lamp like on a snowblower.
The auxiliary fuel tank that came with the bike started to leak fuel after a few days. The mount holes have stress cracks. I mounted up the white engine mounted fuel tank. I plan on getting the tank plastic welded and have both.
