Getting ready to start working on my GT-18 Heathkit Boonie frame, would like to know if there is somewhere I can find a pic of an original motor plate so I can see which holes I need to eliminate to make mine look like it is supposed to. Going to re-install an old 5HP Briggs, so stock original hole layout will work. I know someone cut a notch at the LH rear for a chain to pass thru, that is getting filled. I can see the (4) motor slots, ,the (2) chainguard slots, the kickstand slot, and the fender brace hole. The jackshaft is still bolted down, not sure if it's in the correct holes yet. Not sure about the rest yet, either. Thanks
